7 members (jay d, Bill Hanlon, RaNfLaS, GMCJammer51, DadsFirstPickup, Tyler Watts, Steelonsteel), 94 guests, and 3 robots.
Topics128,048
Posts1,055,663
#1077357 01/05/2015 2:10 AM
I am putting a L6 250 engine in a 1956 Bel Air that originally had a 265 V8 in it. What motor mounts do I need for the L6 250? Can they be bolted on the frame or do they need to be welded? Suggestion on sources for these L6 side mounts.
Many Thanks, Glenn
Last time I checked a Bel Air was not listed in the trucks catalog. Your question probably goes in the Greasy Spoon where someone with the appropriate car knowledge will answer your question. Good luck with your project.
Check with Chassis Engineering
