2 members (Brian Moore, 2-Ton),
158
Mod | | | Forums66 Topics128,113 Posts1,056,279 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | anybody have a diagram for a 56 235 where the oil pressure gauge screws into the block ....changing from 216 to 235 and need to know where the oil filter lines and gauge goes....thanks
| | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | On my 1942 1.5, Its 261 has the oil pressure line teeing of the oil filter line. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2009 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 48 | Hey Maybellene, what's the purpose of the aux oil line? I have seen it a couple times before on other trucks and my truck has this too. I seem to only see it used when an oil filter is added. Does it have to do with the type of oil filter used? | | | | | Joined: Jul 2010 Posts: 592 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 592 | The aux oil line is a back-up bringing oil up to the rocker assembly in case the feeder tube from the oil pump gets clogged with sludge, a common problem with these engines.
It has nothing to do with the oil filter. In fact, the oil filter should help to eliminate sludge.
