| | | Forums66 Topics128,150 Posts1,056,985 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | Hey guys, I'm in need of a little help. My 46 1.5 ton unfortunately sat at a friends 300 miles away since April. I went to load it up on a trailer yesterday and it would not go into gear. I could only get it into gear when the truck was shut off and couldn't start it or it would naturally jerk forward. Pressing the clutch pedal seemed to do nothinig. Question, if the pressure plate is stuck against the flywheel, how do I free it up? The whole clutch set was new December 2010. I know the release bearing is not working properly. I had to use my trailer winch to load it up. Any thoughts would help. Thanks
| | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | i used a big screwdriver to gently free mine up, with patience it came loose with zero damage Indy
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | start it in low and allow it to start moving, then hold the clutch down and hold the brakes. the engine should brake the clutch loose. Danger is involved if you can not stop it. You will have to shut off the key.
1953 Chevy 3100 261 and SM420 53Chevy 31001953 Mack Firetruck 1972 Porsche 911 1986 Honda Goldwing
| | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | Ok, thanks for the input. If either of you don't mind I may send you a PM and ask for your phone numbers to discuss it further. My brother and I were going to try and free it up tomorrow, however the weather is going to be bad. I put a 10.75 inch clutch back on it in December of 2010, any advantage to switching to an 11"? I see more 11" kits available and I know I'll have to replace the flywheel. Does anyone know who makes a good master rebuild kit for the 4 speed transmission? Thanks
| | | | | Joined: Mar 2004 Posts: 6,233 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,233 | To break the clutch free put the truck in High Gear (4th), place two wheel chocks about one foot in front and behind the rear wheels so when it breaks free it doesn't roll away, release the parking brake and rock the truck by hand back and forth. This method has worked for me in the past. The 10-3/4" Clutch Disc is the shock size for your truck. I don't think there would be any issues using an 11", it will grab a little sooner and be less likely to slip under heavy load. Any good machine shop should be able to resurface your existing flywheel. Mike B  | | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | Thanks Mike, We'll also try that tomorrow.
| | | | | Joined: Dec 2014 Posts: 1 Moderated | | Moderated Joined: Dec 2014 Posts: 1 | Haven't heard how you made out with the stuck clutch, so here's another option for you (I like Materman's screwdriver method if access isn't too difficult). Another thing you could try if you can find a lonely road is similar to MtneerMike's method. Instead of using the brakes though, once you are moving along in first or second gear, depress the clutch and then fairly aggressively accelerate and decelerate a few times in rapid succession. You can repeat this several times if you need to. This has worked well for me on the several times I've had customer vehicles with this same problem, and no harm done. | | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | Hi guys, temps were about 40 today in KC so we tried to free it up again with no success. We did find way to much free play in the pedal and adjusted accordingly with no success. I removed the dust cover but the 10.75" pressure plate encloses the disk so a no go on using something to move the disk away. The bearing and pressure plate appeared to be working but you never really know. The truck is heading to the shop Tuesday for repair as its too cold now to do it outside. Thanks for all the advice. | | | | | Joined: Sep 2010 Posts: 1,717 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,717 | This has happened to me 2 different times. I found that I could start the truck in neutral and let it idle for 30 minutes. Then put it in gear and start it and it breaks free. It may take longer in your colder weather.
It seems the materials in the clutch disc will stick to the flywheel when put away warm and left to sit for an extended time. Putting heat into the clutch disc softens the material and lets it release.
I've tried to remember to put a 2x4 against the seat and the depress the clutch pedal when I know it will sit for a while
Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | Thanks Wayne, If I had more time I would keep working at it, but the truck needs to be somewhere Friday and I need it fixed without delay. I hate rushing! hate it, hate it!!! I will never leave my truck at another's house 300 miles away again.
| | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | Just an update, the disk was in deed frozen to flywheel. I was told we couldn't have freed it up without tearing it apart. Truck is fixed and resting comfortably in a warm dry shop. Thanks to all for the advice. | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Your truck was saying "drive me more". Glad it worked out. | | | | | Joined: Mar 2004 Posts: 6,233 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,233 | Congratulations on getting it free...so which trick finally worked? Mike B  | | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | LOL, I know this is almost 4 years late, but the final method was tearing it open and replacing the whole kit. The disk was stuck pretty good, even prying it off with the pressure plate gone was tough. It just so happens my 45 1.5 now has the exact same problem. I went back and reviewed all the suggestions and it won't budge loose so it also is looking at a complete kit. The throw-out bearing was already howling a bit so its not surprise. Thanks | | | | | Joined: Feb 2016 Posts: 1,994 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,994 | Mine was full of mouse nest, the bell housing was packed. Acid mouse urine froze the throwout bearing to the input nose. I had to remove the tranny, clutch, bellhousing in one piece before I could tear it down.
| | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | Did they get in through the bottom inspection plate? | | | | | Joined: Feb 2016 Posts: 1,994 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,994 | I think they got in through the fork hole, no boot, the inspection cover is pretty tight.
| | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Yes - good thinking/curiosity Also, good links | | | | | Joined: Aug 2018 Posts: 18 New Guy | | New Guy Joined: Aug 2018 Posts: 18 | I think it depends on on your clutch style .. IE short diaphram or long diaphram, long brg. for short diaphram and short brg. for long diaphram. | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Difference between the 2 classicparts.com Throwout bearings 1. Clutch Release Bearing for 1938-75 Chevy Truck 1 7/8" Tall. Normally used with the diaphragm style pressure plate. 2. Clutch Release Bearing 1951-84 Chevy Truck 1 1/4" Tall. Normally used with the 3 finger borg and beck style pressure plate. 1929 - 1957 Chevrolet Master Parts & Accessories Catalog Group # 0.799 BEARING, Clutch Throwout 38-54 ALL (ball bearing Type) (1 7/8 long) Part # 909422 Diaphragm Spring Type Clutch Parts1955-56 Coil Spring Type Clutch Parts1929 - 1954 Master Parts and Accessories Catalog Diaphragm - Spring - Bolted Type Clutch Parts | | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | How can you tell a short diaphragm vs long by looking at it? I obviously know the difference between a diaphragm vs three finger. | | | | | Joined: Aug 2018 Posts: 18 New Guy | | New Guy Joined: Aug 2018 Posts: 18 | How can you tell a short diaphragm vs long by looking at it? I obviously know the difference between a diaphragm vs three finger. If you look at some online images you can see that short diaphragm fingers appear flat in design and the long diaphragm fingers have a bend at the ends and are somewhat more raised which would require the shorter release brg.
