| | | Forums66 Topics128,049 Posts1,055,634 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 15 New Guy | | New Guy Joined: Oct 2011 Posts: 15 | Can someone give me instructions ion how to replace the gear in the transmission that the spedo cable is connected to. 52 Chev 1/2 ton four spd. trans | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The speedometer drive gear is pressed onto the u-joint yoke/flange that attaches to the transmission.
| | | | | Joined: Sep 2001 Posts: 581 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 581 | Green,
I'm curious - what leads you to ask? I haven't ever heard of this gear needing to be replaced. Is your speedo sloppy or not working?
-Michael | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Mine needed to be replaced because of two things: - change in rear end ratio (Bruce Bugay sold me a set to match the 3.55 R&P conversion) - new or replacement u-joint assembly with no drive gear
Other possible reasons: - worn teeth on old drive gear? - drive gear for different rear-end ratio (replacement transmission from a bigger/smaller truck)
| | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | If though your speedo is reading wrong due to a different rear end gear size or tire size, how about looking into installing a gear ratio adapter?
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
