4 members (originalchuck, TooMany2count, Chip O, Hotrod Lincoln), 78 guests, and 2 robots.
Topics128,024
Posts1,055,392
Members48,422
#1076404 12/31/2014 10:47 PM
Can someone give me instructions ion how to replace the gear in the transmission that the spedo cable is connected to. 52 Chev 1/2 ton four spd. trans
The speedometer drive gear is pressed onto the u-joint yoke/flange that attaches to the transmission.
Green,
I'm curious - what leads you to ask? I haven't ever heard of this gear needing to be replaced. Is your speedo sloppy or not working?
-Michael
Please type slow, as I can't read very fast.
1939 Chevy/Central Fire Engine
1941 Chevy/American Fire Engine
1950 Chevy/American Fire Engine
More Photos in Me Gallery
Mine needed to be replaced because of two things:
- change in rear end ratio (Bruce Bugay sold me a set to match the 3.55 R&P conversion)
- new or replacement u-joint assembly with no drive gear
Other possible reasons:
- worn teeth on old drive gear?
- drive gear for different rear-end ratio (replacement transmission from a bigger/smaller truck)
If though your speedo is reading wrong due to a different rear end gear size or tire size, how about looking into installing a gear ratio adapter?
Craig
