0 members (), 182 guests, and 1 robot.
Topics128,108
Posts1,056,228
Members48,436
Well folks I am of the old school of oxy/ace welding and brazing school. I never needed a skinkin mig welder!! Ha I finally thought I would buy me a little miller for $200 Bucks and decided if I didnt like it I wouldnt be out much.I also hate bondo with a passion and have stated so numerous times on here. Well I recently found another 54 and the rear bed panel looked better then the one I had, so I wired brushed it found a couple of rusted through places and said huh let me test this mig on this. so after removing the rusted area, I wound up with a 4" long by 2" wide hole. I started circling the outside on low temp and slow speed filling in the hole. 30 minutes later filled in ground down and spot putty covering for smothing. Ok I am sold on the new way of life. No laughin you old timers
Thanks to all helped me to believe
Alan wink :p grin
Live every day to the fullest for tommorrow never comes!!!
I'm in the market for one now. Have been using one in a tech school welding class and I'm sold. Miller s'posed to be a good brand I hear.
Oh yea, you must not be doing something right if any form of welding is as good as an orgasm. That's what I originally meant to post.
rwise
allis well in all departments laughin just the expression I use when I find something I like
Alan grin :p wink
Ok, when you say slow filling the hole, did you weld a patch into the bed. I'm starting tearing off my fenders this spring, and they need a little work! Now, I like metal, although the old man swears by angel hair filler. Is there a book around that will show me beginning welds with a small mig welder? eek
They're more fun shared with others (the trucks that is)
Junior Member
Junior Member
Check out the post welding ?s answered. Good welding info.
42 11/2 ton 4x4 military Chevy
54 JD 40 crawler
58 JD 420 crawler
http://community.webshots.com/user/eal4x4
Quote
Cool thanks.
Thanks for the info, I cut my driving (operating) teeth on a deere crawler that my dad had. We used to hook it up behind a 3800 Panel (the one that I now own), and make a little spending cash on the weekends!
