7 members (LAROKE, Stovebolt48, Tronman, Bwana-Jim, Otto Skorzeny, Lightholder's Dad, 1 invisible),
72
Mod | | | Forums66 Topics128,042 Posts1,055,511 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2014 Posts: 23 'Bolter | | 'Bolter Joined: Oct 2014 Posts: 23 | Have a flywheel out of a 54 235. Gm2 number looks like 838754-777 Has 6 holes and measures ~ 13.5" tooth to tooth Looking for clutch an plate size for this flywheel
Drew 1954 3104 3 window
| | | | | Joined: Aug 2004 Posts: 1,417 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,417 | If the flywheel is stock, you would be amazed at what you find at your local FLAPS. I did a quick NAPA search and here's what I found.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | As Sweet posted, try to buy locally, so you can bring in your flywheel to make sure the pressure plate fits the holes in the flywheel.
In my area, NAPA, Advance Auto, and AutoZone had clutch assemblies that matched two different flywheels.
Buy the assembly, because it will have a throw-out bearing that matches the pressure plate.
| | | | | Joined: Oct 2014 Posts: 23 'Bolter | | 'Bolter Joined: Oct 2014 Posts: 23 | Seems you are in my backyard so to speak. Do you know of any good engine shops in or out of the area ? Thanks Andy
