1 members (JW51), 96 guests, and 0 robots.
Topics128,050
Posts1,055,643
#1076081 12/30/2014 1:04 AM
Have a flywheel out of a 54 235. Gm2 number looks like 838754-777
Has 6 holes and measures ~ 13.5" tooth to tooth
Looking for clutch an plate size for this flywheel
Drew
1954 3104 3 window
ODSS Lawman
ODSS Lawman
If the flywheel is stock, you would be amazed at what you find at your local FLAPS. I did a quick NAPA search and here's what I found.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
As Sweet posted, try to buy locally, so you can bring in your flywheel to make sure the pressure plate fits the holes in the flywheel.
In my area, NAPA, Advance Auto, and AutoZone had clutch assemblies that matched two different flywheels.
Buy the assembly, because it will have a throw-out bearing that matches the pressure plate.
Seems you are in my backyard so to speak.
Do you know of any good engine shops in or out of the area ?
Andy
Drew
1954 3104 3 window
