Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
8 members (homer52, JW51, Hotrod Lincoln, cmayna, Guitplayer, Possum, Joe W, UtahYork), 518 guests, and 1 robot.
Topics126,776
Posts1,039,271
Members48,100
Most Online2,175
Jul 21st, 2025
#1075805 12/28/2014 5:46 PM
Picked up a pretty nice hvlp gravity fed gun at a swap meet, one small problem trying to get some dried paint off of it. Maybe some acetone or laquer thinner? Oh another question my instructions on mixing surface primer is hard to read it looks like 4 parts primer to ? 1 part hardner, the ? is what I can't read, THE BRAND IS ppg.
ol' 55 #1075838 12/28/2014 9:04 PM
Can you search the web for the P-sheet from PPG? Are you using K38 or what? It won't hurt to try lacquer thinner or some red scotchbrite.
Eric
http://s1199.photobucket.com/user/sparky234/library/My%2057%20Chevy%20Stepside?sort=3&page=1
'57 Chevy 3100 (Little Red)
'81 RD350 LC - Fun, Fun, Fun
'83 GS1100E - Pocket Rocket
ol' 55 #1075949 12/29/2014 6:15 AM
soak the parts in lacquer thinner for a few minutes or more as necessary. Anything except 2 part epoxy will loosen right up.
ol' 55 #1077819 01/07/2015 4:56 AM
I will disassemble my guns once or twice a year and soak them in lacquer thinner 24-48 hours and scrub them with a red scotchbrite...
K38 mixes 4:1 http://www.benspaintsupply.com/wp-content/uploads/2011/06/RestTrainingDoc2.pdf
Really depends on what primer you have as to what it mixes with. Also, it doesn't list it on the P sheet but you can thin K38 with DT reducer if you need to. Makes it go on smoother. My method...
1st coat of surfacer Slicksand Block with 80 or 180 depending on quality of body work
2nd coat of surfacer 4:K38 1:K201 Block with 280-320
3rd coat of surfacer 8:K38 2:K201 1:DT870 Block with 320 then 500
Ready for paint!
Randy Domeck
Indianapolis Fabrications
rdomeck@me.com
Indianapolis, In. 46254
317-258-0039
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.065s Queries: 14 (0.063s) Memory: 0.6064 MB (Peak: 0.6443 MB) Data Comp: Zlib Server Time: 2025-09-22 15:39:32 UTC
Valid HTML 5 and Valid CSS
