5 members (MNSmith, Phak1, Gdads51, joe apple, 1 invisible), 72 guests, and 4 robots.
Topics128,180
Posts1,057,141
Members48,463
Hi,
I wonder if someone who knows tire size and drive line could comment. I am trying to figure out if a truck I am looking at is up to my task. Specifically I wonder if a stock 36 Chevrolet truck is capable of running 50mph.
Tires are 6.5 X 20 so if I understand things right that gives a height of 33 inches and about 612 turns per mile. With a ratio of 5:43:1 that means about 2765rpm. I don't think the engine should be run much above 2000 (?) or so.
Tom
Your going to be doing good running 40-45 with your 36. The other side of the coin is stopping it. I had a 34 Chevrolet firetruck and stopping it was always my biggest issue.
it might get to 50 Tom, and with no load might hold it for awhile ... according to the Info Kit [get a PDF here], the 207 [if it still has that] was 'advertised' as capable of 3800 RPM ["engine revs per mile in high gear = 3447"] - likely most of them were run those revs when fully loaded - and run to death .... your choice grin
If you feel you have the power,you can go up a size or two on your tires. I see a lot of trucks that size running 7.50 or 8.25's,and the added height may get you to 60 mph or so. I'm pretty sure with the stock engine you won't have enough power to go any faster than you can now with any kind of load.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
Crusing in the Passing Lane
Again, look at your braking capacity. Those trucks are geared for slow or slower speeds, not only because of the small engine, but because of marginal brakes for higher speeds.
