| | | Forums66 Topics128,029 Posts1,055,417 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2014 Posts: 10 New Guy | | New Guy Joined: Dec 2014 Posts: 10 | Hi everybody I'm new here, I have a 71 C-10 with a 250. I'd like it to be all it can be street wise. Going slowly in stages. Intake, carb then exhaust. Maybe a rv type cam. I'm running a Saganaw three sp. 4/10 gears rear end. I'm not building a Hot Rod but a shop truck 6 with some grunt. I'm also interested in lump port heads. Well hello again, hope to make some friends here. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Hi Ryan, welcome. You have lots of options. If you plan to do some real modifications, check out the HiPo shop. Don't be afraid to keep the 250. Have fun!
Leo | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Welcome to another Bolter. Glad to have you aboard. You'll find bolters here willing to help with what ever you need. Lot of knowledge and folks here. Ask questions in the best garage forums for the best responses and solutions. | | | | | Joined: Dec 2014 Posts: 10 New Guy | | New Guy Joined: Dec 2014 Posts: 10 | Thanks guys, I just need to figure out what the best parts combo is for a daily driver with some 200 - 250 horses. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | guys over in the engine forum will certainly have opinions,or let you know what they have done. With the 410 rear end it probably already has quite a bit of grunt. Might even be called a stump puller  | | | | | Joined: Dec 2014 Posts: 10 New Guy | | New Guy Joined: Dec 2014 Posts: 10 | It really likes 55-60 mph on the high way. | | |
