1 members (UtahYork),
80
Mod | | | Forums66 Topics128,049 Posts1,055,637 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 172 | i think this has been asked before but i,m unable to find the thread where is the frame number located on a 1951 gmc 451 as at present i,m having a dispute with the DVLA which is the uk equivalent of the DMV they have issued a V5C better known here as a logbook /registration document which i suppose is the equivalent of a us registration title and in there wisdom they have dated my truck as a 1948 which it is clearly not so i really need to find the frame number to rienforce my argument with them thanks mike
merry christmas,,
live or die do it with spanner in hand
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I do not think a frame number was used by GMC in your year.
Is there an ID plate on the inside of the glove-box door or between the hinges on the driver's side of the cab?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | frame numbers weren't in general use until after 1955, but I think some GMCs had numbers stamped on the frame rail at the front of the pass side - if not there, nowhere .... also note that GMC didn't change up numbers yearly, very likely that 51 continued a series numbering from 47 .... look around hereBill | | | | | Joined: Oct 2011 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 172 | thanks ,red, i,v studied that but i,m not much wiser as i can,t find any mention of a 451 i,v cleand the frame both sides and can,t see any numbers i,v got the parts identification plate of the glove box door and the serial number on it reads as follows model 451 serial 15187 engine 270 f,axle clark f460 r,axle eaton tspd 16600 ratio 6.50/9.04 trans clark 202v ,, 5dd. brakes vac wheels motor 6 stud
which is all ok eccept the serial number isnt what the dvla has used to register the truck and its been converted to air assisted brakes by having the vac servo changed for an air one she,s set up as a semi tractor, and has an after market comppressor and air equipement all of which looks to be factory options but no mention of it on any plate anywhere
what doe,s the HC stand for ==heavy commercial ?? any information anybody can offer me would be most gratefully recieved i had threatened to sell this truck as i,m going through some hard times both financially and health wise but i just havnt got the heart to sell and intend restoring it and finding/building a suitable trailer so as i said i,d be most gratefull for any help
,,mike,,
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Check out www.oldgmctrucks.com for Tech. Info., on your truck. I've never found a frame stamped number on any '47-'54 model truck, I've disassembled. Do you still have the "GMC Parts Idetification" Tag, on the back side of the glove box lid ? "HC" is just a model number for '47-'51 model Heavy Duty Trucks. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | "There are also multiple letter codes for larger trucks indicating a COE, tandem axle, or diesel engine. GMC didn't really look at truck "years" so much as at did model runs which in many cases ran for multiple years." see here, and for the HC451 see here - the letters should indicate a 50-51 truck, a 48 would be FF451, print out the list and take it to your officials Bill | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Where did you find the HC? HC-451 1950-51 with 37 inch wheel baseMerry Christmas | | | | | Joined: Oct 2011 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 172 | the HC is on the parts identification tag of the glove box lid
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I see that Bill beat me to it. Do you have a figgy/plum pudding during this the holidays? | | | | | Joined: Oct 2011 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 172 | figgy/plum pudding well i,m more of a trifull /jelly,custard,n cream sort of man myself but yes we do have a traditional rich/fruity christmas pudding there will be much eating /drinking and getting fatter later this week ,,lol,,
| | | | | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | H = 1950 and 1951 production C = Conventional Cab 45 = 450 series 1 = 137" wheelbase 15187 = regular sequential chassis serial number
There are no numbers on the frame so you can stop looking. I suspect that truck is a '51; turn down door handles and vent windows? | | | | | Joined: Oct 2011 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 172 | H = 1950 and 1951 production C = Conventional Cab 45 = 450 series 1 = 137" wheelbase 15187 = regular sequential chassis serial number
There are no numbers on the frame so you can stop looking. I suspect that truck is a '51; turn down door handles and vent windows? yes turn down handles n, vent windows allthough busted by gun shot along with a few nice bullet holes in the drivers door,, i wonder whos farmers daughter he was caught with ,,lol,,
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | You might look on the outside of the starboard frame rail, near the front spring shackle mount, large stamped letters.
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Ed, You won't find a number on the frame rail, of the 47-55.1 model years. I've looked on numerous trucks. It is stamped in that location on '46, & older GMC trucks. | | |
