| | | Forums66 Topics128,185 Posts1,057,294 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 154 'Bolter | | 'Bolter Joined: Mar 2014 Posts: 154 | I did some searching, but couldn't find where this has been discussed. This is the first full winter I've had my AD truck and I live in the very damp Pacific Northwest. I keep my truck under cover, but noticed recently that with temperature/humidity changes, I'm getting a lot of moisture inside the truck. Obviously these old trucks don't seal up too well. Has anybody else solved this problem with either an electric heater or desiccant?
Greg Brown
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | This is a good topic, I'd be interested also. Not all of us are able to garage our trucks inside. I guess desiccant might work as long as the temperatures stayed above freezing. In the basement we use to stretch a piece of cheese cloth over a gallon ice cream bucket and pour desiccant in the cheese cloth, the absorbed water would drip into the bucket. John | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | only thing you can do Greg, is keep the windows open so the inside temp and humidity stay the same as ambient outside, the condensation happens after the inside warms up and the higher humidity condenses on the cold outer surfaces
Bill | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | When I lived in Ohio I kept one of my cars in a pole barn that had a concrete floor. When I stored it in the winter I put the car in a Carjacket. http://www.carbag.com/It's a zippered plastic bag (think plastic tarp type material) you put the vehicle in. They also sell large perforated steel cans of desiccant as well as bags of desiccant. What I did was unzip the bag, drive the vehicle onto it, remove the battery, prop the hood and trunk partially open, roll the windows half way down, place a desiccant canister inside the vehicle, place another under the vehicle, put the car cover on the car, then lift the rest of the bag over the vehicle and zip it up. The desiccant containers can be re-used after baking them in an oven. Worked great. I now live in Colorado, dry enough that I no longer "bag" the vehicles. Hope that helps  John | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | point is, is Greg asking about long term winter storage?
Bill | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | point is, is Greg asking about long term winter storage?
Bill As we all are, Bill, I do believe. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | that point isn't really what Greg is looking for, that's for garage queens .... in the PNW with weeks on end of humidity around 100% and temps fluctuating from freezing overnite to well above in the day, keeping it 'under cover' doesn't prevent interior condensation, and using the vehicle, or working on it regular makes it rather impractical to 'bag it', the only practical solution is to keep the inside and outside the same temperature and humidity, heating the interior will increase condensation and desiccant without the bag would need to be changed 4 times a day  Bill | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | You can do it fast, You can do it cheap, or You can do it well.... pick two. That rule works pretty much with everything in life. If the bag is too impractical (not fast enough) park "ye ole bolt" in a shop with a heater, air conditioner and a humidifier. (expensive) John | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I helped a buddy restore a 56 panel, he stashes it in the breezeway beside my building every winter, windows open, never had any condensation problems even when the concrete is wet for weeks ... long term storage or daily use, you can have all 3 in the rain forest, park it under cover, open windows, head inside for a beer  Bill | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | Winter + Rain Forest + Breezway + Windows Down + Drinking Beer + Fast + Cheap + Well = No Condensation... got it. | | |
