1 members (Hotrod Lincoln), 41 guests, and 0 robots.
Topics128,035
Posts1,055,560
#1074748 12/22/2014 1:24 PM
First when I shut the door it rubs the top of the striker plate yet the door looks to be as far up as it can go on adjustment without hitting the top. Second, when the door latches, there is about 1/8 inch play in the door?
Good stuff! Thank you!
Chaney, last evening I was looking in the Tech Tips section here and ran across a lot of good info on what you are doing,would be worth your time to take a look. Pat
1966 Chevy C 30 1 ton truck
Moderated by  ndkid275, Phak1
