3 members (GIJOE298, Peggy M, 1 invisible),
123
Mod | | | Forums66 Topics128,078 Posts1,056,056 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | For over 50 years I swore by the old peep hole helmets and changed lens shades for different amperage. A friend of mine who has been using the same helmets for as long as I have recommended one of the Jackson Nexgen. Last week when Zoro had their 30% off day, I bought one of these. http://www.zoro.com/i/G4019687/I am amazed by it. Welding light materials depends on what you do right after you strike the arc. Otherwise you burn a hole. I am amazed with the new helmet. I can see whats going on the second I strike the arc and that is a big factor when welding thin stuff. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Holy smokin' cow Ken!!! $506.63------You can buy a 50" big screen T&V for that kind of coin. I thought I was really being extravagant when I blew $250 on my Miller Elete helmet a few years ago. Used the old dump helmets up till I sprung for that Miller and still can't get out of the habit of nodding my head with my new 'lectronic sun shade. Some habits are just to hard to break.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Feb 2007 Posts: 434 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 434 | I spent about 400 on an Optrel Satelite nice hood unail the battery died and they wanted about 75 percent of purchase price for a new lens piece integrated with the battery.
Bought a cheap Northern Tools which is ok but the head gear was cheap and uncomfortable. Now have a Save Phace which is a decent compromise between cost and function at less than 200 if I recall correctly. If I welded for a living a comfortable 400 dollar hood would be more than worth it.
Hard to tell much difference in the lens darkening mechanisms between the ones I have used and I suspeCT it is duplicate integrated chip circuits that results in close to the same working mechanism.
R-Bo
1959 Apache 1/2 ton Big Window, Short bed Fleetside (under reconstruction) 1966 GMC 305V6 in the family
| | | | | Joined: Feb 2012 Posts: 96 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 96 | kind of like my Lincoln viking with the big window when the battery died just went down to batteries plus and got a new one, well actually got 2 one to use and a spare.
that big window is much easier to see out of then the cheapie HF one that bought first.
doing body or frame work and well a good helmet will prove worth the cost. amazing how much it improves your welding skills | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | What I like the best about these new helmets, I have the Viking 3 is the magnifying lenses that slip into the window. WOW did that ever change things for me. Once you get over the amazement of the way these new solar units work, check out the magnifiers. Just keeps getting better!
