| | | Forums66 Topics128,093 Posts1,056,480 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 271 'Bolter | | 'Bolter Joined: May 2012 Posts: 271 | So I had to move my frame over in the shop and I took some 95 dodge dually wheels and tried to put them on my 54 3800 and THEY FIT! I thought they weren't supposed to clear the 14" drums??? Also tried late 70's SRW wheels and they fit too...
Took about an hr and a half of prying but i got 1 drum off and everything looks pretty good. think i can even save the shoes. one problem is that about 25% of that reinforcing ring around the OD of the drum rusted off but for my use i think it will be fine.. tj | | | | | Joined: May 2012 Posts: 271 'Bolter | | 'Bolter Joined: May 2012 Posts: 271 | nevermind... sounds like a clearance issue in the front unless you use spacers i guess tj | | |
