| | | Forums66 Topics128,085 Posts1,056,329 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 42 | I have a T connection on my 1959 front brake lines (drivers side)that connects the hard lines to the flex front left wheel.
The issue I'm having is that the bolt that goes thru the brass connector and connects to the flex line has slop and can move when all three connections are made. Is this normal?
Thanks in advance for any guidance here. I'm using the brass fitting and bolt that was on the truck when I bought it. | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Do you have the flat brass washers, grooved like a record? You need 2. One for each side of the block. If you don't the bolt will be too long.
Steve H
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | As Steve posted, you should put a copper/brass washer on both sides of the block. They do not have to be grooved. http://www.classicparts.com/1941-66-Brake-Hose-Copper-Washer/productinfo/71-301/#.VJA7WidlVDENAPA and other parts-places sell soft copper/brass washers with different inner/outer diameters and thicknesses. They make the seal on both sides of the brass block, and they allow the bolt to seat properly. | | |
