9 members (Phak1, Bill Hanlon, Rusty Rod, TUTS 59, Napco Man, Cosmo, ndkid275, 2 invisible),
57
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2002 Posts: 53 | Hello everyone, I’m starting to assemble the front clip to my 59 truck. I was wondering if anyone tell me how thick the shim is that is under the radiator support ? Thanks for all your help !
Clem 59 Chevy 3600 New Hampshire
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Clem,
Wait to hear from someone who knows 55-59 trucks/shims.
In earlier years, the number of radiator shim/shims and thickness of the shims was whatever was needed to align the front end sheet metal.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | not a shim really, but a large fat washer as shown here, and a rubber washer - and same set on top Bill | | | | | Joined: Mar 2002 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2002 Posts: 53 | Thank you Red. I was wondering how thick that washer was. I'll start with a normal flat washer.
Thanks again
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | they're unusually thick for a washer that diameter, which most commonly are the real thin "fender washers" - at a guess maybe as much as 1/8" - about the same as the rubber cushions there
Bill | | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | Clem, ...... In earlier years, the number of radiator shim/shims and thickness of the shims was whatever was needed to align the front end sheet metal. This is what I would suggest. Shim until you have a nice consistent gap top to bottom between the front edge of the door and rear edge of the front fender on both sides. | | | | | Joined: Mar 2002 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2002 Posts: 53 | Thanks MPandC ! Thanks everyone ! Clem
