8 members (Leo, Dennys28, Twinshadows, Wayne67vert, Hotrod Lincoln, 46 Texaco, Still At It, GRNHydra), 112 guests, and 2 robots.
Topics128,087
Posts1,055,977
Members48,430
Hello everyone,
I’m starting to assemble the front clip to my 59 truck. I was wondering if anyone tell me how thick the shim is that is under the radiator support ?
Thanks for all your help !
Clem
59 Chevy 3600
New Hampshire
Clem,
Wait to hear from someone who knows 55-59 trucks/shims.
In earlier years, the number of radiator shim/shims and thickness of the shims was whatever was needed to align the front end sheet metal.
not a shim really, but a large fat washer as shown here, and a rubber washer - and same set on top
Thank you Red. I was wondering how thick that washer was. I'll start with a normal flat washer.
Thanks again
Clem
59 Chevy 3600
New Hampshire
they're unusually thick for a washer that diameter, which most commonly are the real thin "fender washers" - at a guess maybe as much as 1/8" - about the same as the rubber cushions there
Clem,
...... In earlier years, the number of radiator shim/shims and thickness of the shims was whatever was needed to align the front end sheet metal.
This is what I would suggest. Shim until you have a nice consistent gap top to bottom between the front edge of the door and rear edge of the front fender on both sides.
Thanks MPandC ! Thanks everyone !
Clem
Clem
59 Chevy 3600
New Hampshire
