0 members (),
38
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2013 Posts: 9 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 9 | I have a carburated 350 (target engine) that used to have an auto tranny behind it. I have a 3 speed OD that I would like to use with this engine in my 66 half ton. The 3sp OD was on a 265, the 265 bellhousing bolts up okay to the 350. The trouble is the starters, the old one is 3 bolt and the one that was on the 350 is 2 bolts. What direction do I need to go to fix this problem ? Any ideas or suggestions would be appreciated. | | | | | Joined: Aug 2012 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 28 | I did a similar swap. What I used was the 3 bolt starter, just had to grind a bit off the top ear to clear the 2 bolt mount on the block.
1954 GMC 9314 - 261 t5
| | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | There are no physical differences between the 265 engine and the 350. The bellhousing, flywheel, and 3 bolt starter will all bolt up. Make sure you have the truck bellhousing, however. A car bellhousing will not match up with the mount positions on the crossmember. Fred
