| | | Forums66 Topics128,130 Posts1,056,370 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 29 'Bolter | | 'Bolter Joined: Apr 2013 Posts: 29 | I pulled a spare tire mount off the side of a 54 chevy pickup,I notice the triangle bolt pattern is offset, the top two are 4 5/8" center to center but from a top one to the bottom bolt is 6" C to C.there was another (i believe 54)next to it with the same mount but the 3 bolts were all the same CtoC..The truck I pulled it off had 6 hole wheels..What do I have? | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | Just a guess here, but is it possible that a 5 hole rim required a different size triangle in order for 3 holes to bolt up to that mount than a 6 hole would? I've not measured them--as mentioned, this is just a guess. | | | | | Joined: Apr 2013 Posts: 29 'Bolter | | 'Bolter Joined: Apr 2013 Posts: 29 | The more I look at it I'm pretty sure its for a 3/4 ton 8 hole wheel. | | |
