0 members (), 80 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
#1073178 12/13/2014 11:49 PM
I pulled a spare tire mount off the side of a 54 chevy pickup,I notice the triangle bolt pattern is offset, the top two are 4 5/8" center to center but from a top one to the bottom bolt is 6" C to C.there was another (i believe 54)next to it with the same mount but the 3 bolts were all the same CtoC..The truck I pulled it off had 6 hole wheels..What do I have?
Just a guess here, but is it possible that a 5 hole rim required a different size triangle in order for 3 holes to bolt up to that mount than a 6 hole would? I've not measured them--as mentioned, this is just a guess.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
The more I look at it I'm pretty sure its for a 3/4 ton 8 hole wheel.
