Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Gdads51, Stewart2, Otto Skorzeny, 1 invisible), 85 guests, and 1 robot.
Topics128,292
Posts1,058,598
Members48,492
I have a carburated 350 (target engine) that used to have an auto tranny behind it.
I have a 3 speed OD that I would like to use with this engine in my 66 half ton.
The 3sp OD was on a 265, the 265 bellhousing bolts up okay to the 350.
The trouble is the starters, the old one is 3 bolt and the one that was on the 350 is 2 bolts.
What direction do I need to go to fix this problem ?
Any ideas or suggestions would be appreciated.
I did a similar swap. What I used was the 3 bolt starter, just had to grind a bit off the top ear to clear the 2 bolt mount on the block.
1954 GMC 9314 - 261 t5
There are no physical differences between the 265 engine and the 350. The bellhousing, flywheel, and 3 bolt starter will all bolt up. Make sure you have the truck bellhousing, however. A car bellhousing will not match up with the mount positions on the crossmember.
Fred
