1 members (carbking), 77 guests, and 3 robots.
Topics128,196
Posts1,057,393
Members48,471
#107288 12/10/2004 3:29 PM
Anonymous
Unregistered
Anonymous
Unregistered
I am rebuilding the hinges on my 54 and have learned several things about this activity such as a good way to get the old hinge pin out with less than fifty dirty words. Sadly though, one of the things I have yet to learn is how to get the two springs to fit in the top hinge without breaking them.
If someone has learned the trick to getting these springs to stay where they are meant to be while still allowing the new pin to be installed I would be grateful if you could share your knowledge.
Yes I have searched the archives but none of the past threads or links deal specifically with the spring installation issue.
At this point I will accept good guesses also.
Many thanks.
#107289 12/10/2004 6:09 PM
I am getting in line behind you, waiting for the answer. My machinist did my hinges but can't get the springs in without breaking them.
1951 1 Ton Completed
#107290 12/10/2004 7:32 PM
My doors each had 1 spring broken/missing when I took them off so I decided to install new springs when I put them back on. I ordered a new set from Brothers and they promptly ALL broke when I installed them. They sent me a replacement set and they broke also. They were all very brittle metal, perhaps even pot metal, and about 1/16" wider than the originals. I finally found a parts truck and got 2 originals, cleaned them all up and they installed just fine.
The vendors probably get those replacements from the same place. I would start looking for a parts donor. Good luck.
shoeless
#107291 12/10/2004 8:14 PM
Anonymous
Unregistered
Anonymous
Unregistered
Thanks. I do have a few extra hinges that still have the springs but I was hoping to use them as ebay fodder. Currently thinking about fabricating another means to keep the door from swinging too wide.
Has anyone designed an alternative to the springs?
There has to be someone out there who has suffered successfully through this.
