| | | Forums66 Topics128,108 Posts1,056,238 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 4 New Guy | | New Guy Joined: Sep 2007 Posts: 4 | will 1940 chevy dump truck front fenders fit on 1940 1/2 ton chevy pickup | | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | 1939-40 1/2, 3/4 ton front fenders are the same, but they are smaller than the 1939-40 1, 1-1/2 ton which are larger to accommodate the larger rims/tires. So no they won't fit if that dump is the larger truck. The running boards are different also.
1939 Chevrolet Stake Truck
| | | | | Joined: Apr 2006 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 62 | rickmg, beejs53.According to my books all front fenders for 1939 fit 1/2 ton(JC),3/4 ton (JD) and 1 ton(JE). I purchased a 1 ton from a vendor at Hershey one year that was listed as 1 ton and was he upset when I told him that it also fit my 1939 JC Suburban.He looked it up in his parts book and said I was right. Check your books and correct me if I am wrong.Stan | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | 1/2 ton to 1 ton use the same fenders. Any larger than that and they'll still bolt on but the big truck fenders have larger wheelwells and the front edge is cut different too I believe. | | |
