2 members (mick53, J Lucas), 133 guests, and 2 robots.
Topics128,162
Posts1,056,938
Members48,458
1 Offline
I have a 53 3100 with a 235 engine that came from a 1962 truck. The truck was just finished and has about 400 miles on it. I had a new radiator installed during restoration. I live in Texas and I took it out on a very hot day. About 5 miles from my house, the engine got hot and the radiator boiled over. I ended up having the radiator rotted out and that fixed the overheating problem. I don't have a temperature gauge because I couldn't get any of the replacement gauages to work so I installed just an idiot light which worked fine. After my overheating I would like to also install an aftermarket temp gauge under the dash. Is there another place I could connect it to the motor since I'm using the traditional place at the back of the head for my light? I was told that I could use one of the connections on my water pump. Would that work or is there a better place to connect it? Thanks
1953 3100 Chevy 5 window
1971 Chevelle SS
Use an electronic gauge rather than a manual temp gauge than you can use the same sensor as the idiot light.
Drew
The water pump fittings will be reading the temperature of coolant returning from the radiator, which will be a lot cooler than the stuff leaving the engine. Get a thermostat housing with a 1/2" pipe fitting thread in it, and install the idiot light sending unit there. Then install the regular temp sensor where it belongs, at the back of the head.
Sir Searchalot
Sir Searchalot
I don't think a light sensor is the same animal as a gauge sensor. One is a variable resistor, the other a switch to ground. It is a very good idea to have both types. One for alerting, the other for monitoring.
Hotrod has the solution. Use both. Housing is the same as a SBC so it is cheap as well.
Steve H
1 Offline
Thanks, is Hotrod a parts vendor? Are you saying they have a housing I can use both out of the same location?
1971 Chevelle SS
Nope, just another stovebolter. The thermostat housing that fits a late model Chevy V8 with computer sensors has a 1/2" pipe thread hole in it. Adapt the idiot light sender to that hole and USE THE ORIGINAL SENDING UNIT HOLE IN THE HEAD FOR THE TEMP GAUGE! There's no reason an oldtime bulb-sensor temp gauge won't fit back there and work right.
Sir Searchalot
Sir Searchalot
Hotrod is short for one of the posters "Hotrod Lincoln", the guy above......as in Jerry. It's not the name of a Company if that's what you meant.
I've seen bulb-type temp.gauges,at tractor-supply,Ag stores,for as little as $15.00. If you get one through one of the K.C. vendors,(at least for the T.F. square gauge),they run upwards of $50.00!
Mo' Tater
I've seen a procedure for repairing the bulb-sensor gauges by super-cooling the liquid inside one of those cheap aftermarket gauges in a dry ice/alcohol mixture, and solder-splicing the new bulb and tube assembly onto an original gauge. I've got an old gauge on hand with a bad tube that I'm planning to experiment on.
I'm curious about why the aftermarket gauges for the original dash unit wouldn't work?
Some of the older 216 heads had a tapered seat area for the gauge sender to seal off if my feeble memory serves me right.
The newer 235 did not have that taper, but seems to me I used an adapter the local parts store had to make the stock gauge sending unit fit. Had the tapered seat built into it.
http://www.classicparts.com/1941-54-Temperature-Sender-Reducer-Bushing/productinfo/24-811/
Maybe someone will post a Dorman and/or NAPA, and/or Weatherhead/Eaton part number?
1 Offline
The original Gauge didn't work so I bought a replacement from LMC which didn't work either. After pulling it out for the 4th time I just decided to just drill a hole through the bottom of it and insert a small LED light. As you all know, its very hard to install the factory gauges, especially if you have big hands like me smile
Guys, I appreciate your help on this one. I'll look into these adapters.
1971 Chevelle SS
Sir Searchalot
Sir Searchalot
Some are talking electrical sender, some are talking bulb, Which are you wanting to use? The bulb and sender are one unit and don't care what motor or vehicle it's on. The electrical has to be ohm matched, sender to gauge. Old gauge with new sender does not work sometimes. Electrical is much easier to install, never a stained carpet. Albeit not "original".
1953 stock would have been a bulb / mechanical gauge.
But then his might not be stock.
