1 members (NJC), 132 guests, and 2 robots.
Topics128,162
Posts1,056,941
Members48,458
#1072819 12/11/2014 5:06 PM
The bench seat in my 48 truck has seen its better day. It has been recovered already with new padding but the springs, especially on the drivers side have lost its firmness so its kind of like sitting in a hole. I am trying to keep the truck all original. Can anything be done to the original seat to get back the firmness, can the springs be fixed in any way or is it a lost cause?
Are the springs broken?
If not, a firm seat can be accomplished by reupholstering the seat and putting in at least one layer of firm material.
If any spring is broken, it should be replaced and reconnected to other springs (as originally done).
I think that Denny Graham has a photo-log/write-up on doing this (he will let us know, soon).
You can move springs from the middle of your seat to the drivers seat as long as they aren't broken...the middle springs will be like new as know one ever sits on them, then put the weak springs back in the middle...cheap easy fix. Then install new burlap and dense foam,
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
No help here Tim, my seat was in excellent shape, very firm all
the way across. I even used the original horsehair (rubberized
coir) pad simply replacing the old cotton padding and cover.
If you have broken or weak springs my only suggestion, and the
way I would cope with it, would be to find a donor seat and
scavenge one/ones from that.
dg
Denny G
Sandwich, IL
I had a similar issue with the seat in my 1950, 2 springs were broken. Fortunately I was able to find the same size spring through an online upholstery site. I'm not positive that the spring tension is identical to the originals but it sure feels a lot better on my aching keester. If you need a couple I think I have 3 or 4 extra in the shop, PM me.
BV
Moderated by  ndkid275, Phak1
