4 members (greenie-reddy, pauld, 2 invisible), 85 guests, and 2 robots.
Topics128,266
Posts1,058,368
Members48,485
#1072274 12/08/2014 4:03 PM
awk
Offline
Ok, 12 month ago I converted by 54 3100 to 12V having my gen. rewired and changing the reg. to a 12V reg.
This passed weekend decide to convert to an alternator. Bought the alternator harness and wired it up. Seems pretty easy. Start the truck, checked the voltage at the battery while run, 14.25V, seems ok. Turned off the ign. key, but engine stays running. What did I do wrong?
awk
3B Offline
Hy awk, you are probably using the ignition terminal on the ignition switch as your alternator excitation wire, when you turn the ignition switch to the off position the alternator back feeds the ignition circuit. Depending on which alternator you have, you could install a diode in the alternator excitation wire to prevent backfeeding the ignition circuit, or you could purchase something called DA plug which plugs into the alternators two terminal connection and has the diode incorporated into it, hope that helps.
awk
Offline
3B,
Thanks, but I believe I'm using the DA plug. I ordered an alternator conversion harness from American Autowire P/N 30370 that has the 2 wire plug and the alternator BAT terminal all wired. I have the brown wire going to the ign "ON" terninal of the ign. switch. Still using the original ign. switch which is only "on or off".
I have a GM 3 wire alternator, with internal reg.
awk
awk #1072344 12/09/2014 12:39 AM
3B Offline
Hy awk, I sent American Autowire an "E" mail, they got back to me and said that their p/n 30370 does not contain a diode, their suggestion was to disconnect the two wire plug, start the truck and then try to shut the engine off, if it shuts off with the plug disconnected then it needs a diode in the exciter wire to stop the backfeeding, as I suggested in my first post, hope that helps.
awk
Offline
3B,
I called them too. They told me that 30370 harness did not have the diode and gave me the spec's on the diode. Picked up the diode last night installed it and all is fine now.
Thanks for the help, another problem solved by the great people on this site.
The diode that Autowire uses is 6amp, 400v, NTE5814. I installed a 6amp, 600v, NTE5815. Could not find the 6amp 400v, NTE5814, but the NTE5815 should still work fine. These are actually silicon rectifiers
awk
I install a warning light so I know if there is a problem. At least if you lose a fan belt you know when it happens.
But nothing wrong with using the diode either. Glad you got it figured out.
AAW Rocks!
Mo' Tater
