1 members (Samantha), 45 guests, and 4 robots.
Topics128,179
Posts1,057,159
Members48,465
I have a 54 chevy 1/2 ton truck and I'm needing a crankshaft replaced. What year 235 engine crankshaft will interchange in this engine. And does anyone have a link to where I can pick one up?
1954-62 235 and 1954-63 261 will interchange.
1953 Powerglide 235 will also fit, but I have seen where the hole for the pilot bushing was undersize on these, as these were only used with automatics.
My Blog
H Online: Content
If there is an oldtime automotive machine shop in your area, check to see if maybe they've still got a reground shaft in stock. Some of the machine shops where I've worked never discarded anything, even if it was many years obsolete. There are usually several 235/261 cranks on Ebay, but the shipping cost on something that big and heavy can get pretty steep.
my book shows (Chevy inline 6 number & casting code guide) the casting number 3701488 fits 1953 - 1962 Chevy 235 & 1954 - 1962 Chevy 261. that's what I have in my 235 truck 3100 and its a 1956 motor.
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen
56 Chevy 3100
thanks for the replies, and sorry I haven't replied sooner. I had to carry my dad to the E.R Friday so I have been pretty busy. I checked with the 3 machine shops we have here already. they could turn the crankshaft I have but I would have to pick up the bearings some where else. And I knew that the crank would works in either a 261 or 235 but wasn't sure what years would work. I found that Rock auto had some remans that come with the bearings and they are asking $267.00 + $33.00 for shipping and also charge a $150.00 refundable core charge. My wife found a coupon for %5 off so that would pay for half the shipping. I replaced the crank in a 65 235 and picked up the crank and bearings separately. I ended up with having to return the bearings twice because they had sent the wrong ones. So I figured get the crank and bearings as a kit and wouldn't have the problem. I might spend a extra 15 bucks but at least I would not have the head ache of having the wrong bearings.
I don't think they made a 235 in 65.
1951 1 Ton Completed
Must have meant 230, or maybe that is why he got the wrong bearings.
My Blog
Speaking of bearings, the only main bearings that fit a 1954 235 would be for a 1953 full pressure engine, 1954 all, and early 1955. Mid 1955 the mains changed from pin locating to tang.
My Blog
