1 members (ronsway),
185
Mod | | | Forums66 Topics128,167 Posts1,057,019 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | what holds the motor to the front mount on a 216 motor, I have the carriage bolts mounted to the frame, but the 2 bolts that go thru the front mount and thru the frame have to go thru 2 big holes, is there a piece missing or do I use big washers? | | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | There is some pics of the motor mount in my link.this is 3/4 ton Pic 1 Pic 2
| | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | I have all the parts, but what goes on the bottom of the frame? the 2 holes are big, do I just use washers? | | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | The 2 "inner" bolts hold the mount to the plate on the engine. The 2 outer bolts hold the mount and engine to the cross member. The 2 outer bolts fit into the holes shown in Pic 1 shown above. The bigger holes let the bolts and nuts holding the mount to the plate clear the cross member. If that helps.
Steve H
| | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | I took the liberty of quoting directly from the Tech Tip. Thanks Don Mclendon. "Check to make sure the 7/16" thru-bolts are centered in the large opening in the cross member. If they aren't, and they make contact with the edge of the hole, you'll get vibrations."
Steve H
