0 members (), 129 guests, and 1 robot.
Topics128,115
Posts1,056,292
Members48,439
#1071943 12/06/2014 10:37 PM
I'm going to try and use some photo's, so hopefully this works. I am putting my clutch linkage together, and where the pivot ball meets the frame bracket, is a little backwards to me. The frame bracket has an "L" shaped slot, after the pivot ball thread is installed, there is a small stamped out piece with a round square hole in it. The pictures that I see of this, shows the stamped piece running horizontal, but it seems to work better with it vertical. I also assume that the 2 little fingers that are on the stamped piece, should be bent over into the hole at the corner of the "L" slot in the frame bracket. With it vertical, I see no use for the Horizontal leg of the "L" slot. I know I'm making more of this than it is, but it's just one of those things that seems way over engineered to me. Thank you for your help.
http://s1375.photobucket.com/user/rps2657/library/?view=recent&page=1
Sir Searchalot
Sir Searchalot
EDIT: Your spacer, or also called locking washer, is 90 deg off. Turn it 90 CCW. I believe the short bent leg goes vertical into the long vertical slot. That would put the shaft into the rearward slot. Then star washer and nut on threaded shaft. Bend one small ear, on the lock washer, up to lock the nut.(whichever one is parallel to a flat on the nut or both up).
I just did mine. I took photos when I took mine apart. I also grabbed 2 more from the salvage yard. They were all the same. See photos.
Locking clip
[size:11pt]Nut is on with star washer[/size]
Jay
Riding in the Passing Lane
That locking tab is very important. It keeps the ball stud from coming forward under pressure. It seems without it regardless how tight you get it, it will slip foreward throwing the clutch out of adjustment.
1972 Chevy c10 Cheyenne Super
Sir Searchalot
Sir Searchalot
Good photos LUGNUTZ!
Thank you for your help, makes perfect sense now. I took lots of pic's when I took it apart, but it did not have the stamped metal part in it. Thank you again.
