0 members (), 109 guests, and 2 robots.
Topics128,167
Posts1,057,021
Members48,458
what holds the motor to the front mount on a 216 motor, I have the carriage bolts mounted to the frame, but the 2 bolts that go thru the front mount and thru the frame have to go thru 2 big holes, is there a piece missing or do I use big washers?
There is some pics of the motor mount in my link.this is 3/4 ton
Pic 1
Pic 2
This Tech Tip has some very good pictures and information. It is for the 235, but, the 216 has the same mount.
http://www.stovebolt.com/techtips/engines/motor_mount_front/index.html
Nice information, thanks to Don MCLendon
Steve H
I have all the parts, but what goes on the bottom of the frame? the 2 holes are big, do I just use washers?
The 2 "inner" bolts hold the mount to the plate on the engine. The 2 outer bolts hold the mount and engine to the cross member. The 2 outer bolts fit into the holes shown in Pic 1 shown above. The bigger holes let the bolts and nuts holding the mount to the plate clear the cross member. If that helps.
Steve H
I took the liberty of quoting directly from the Tech Tip. Thanks Don Mclendon. "Check to make sure the 7/16" thru-bolts are centered in the large opening in the cross member. If they aren't, and they make contact with the edge of the hole, you'll get vibrations."
Steve H
