| | | Forums66 Topics128,052 Posts1,055,774 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2014 Posts: 5 New Guy | | New Guy Joined: Nov 2014 Posts: 5 | anyone know, heard many talk about this . is my 64 gmc 4000 cab the same as a 1/2 ton pickup cab? | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | I believe the cabs and doors are interchangeable. Fenders and front bracket are different. Maybe someone can further confirm.
| | | | | Joined: Jul 2008 Posts: 86 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 86 | It is my understanding that the cab, doors and hoods are the same. Inside the cab probably the only difference is the height of the transmission hump since the transmission is several inches lower in a big bolt, making a floormat impossible to find.
If you need any measurements of the 4000 let me know, it's sitting in the driveway.
| | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | I have never swapped one, but have heard quite a few times that the Mounts are different on the Cabs between the two.
Up to now, I really can't actually remember any Pick-ups riding around with a former 2-Ton Cab.
But that said, I'm sure it could be modified to fit. But me personally, I'd want a Pick-up Cab on a Pick-up.
The Floor Hump is also another issue as mentioned, unless you would need one anyway (like I would, lol).
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
