9 members (Jack Ryan, Peggy M, TUTS 59, 1955 1 Series, 2-Ton, Hawkman, baldeagle, 2 invisible),
70
Mod | | | Forums66 Topics128,089 Posts1,056,356 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2014 Posts: 23 New Guy | | New Guy Joined: May 2014 Posts: 23 | I had my 2 ton apart this weekend, trying out a disk brake idea, and noticed the bearings don't look like a normal roller wheel bearing. In addition, they have no rear/inner seal. It looks like you pump grease through the bearings and a little steel hat directs the excess back to the front of the drum, mostly.
How have i never seen this before? I've wrenched for 20 years.
Possible to convert it to normal tapered rollers and a real seal? Our do i just really need to find a p30 axle? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | They are called conical brgs. They were used for many years back then on the wheel brgs & diff. carrier brgs. The replacements are normal tapered roller brgs.You are supposed to replace both inner & outer if you need to replace one. It seems to me it should have a seal in it. Ive been in a lot of them & never saw one without a seal. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
