3 members (1955 1 Series, DadsFirstPickup, Gdads51), 52 guests, and 3 robots.
Topics128,089
Posts1,056,364
Members48,442
I had my 2 ton apart this weekend, trying out a disk brake idea, and noticed the bearings don't look like a normal roller wheel bearing. In addition, they have no rear/inner seal.
It looks like you pump grease through the bearings and a little steel hat directs the excess back to the front of the drum, mostly.
How have i never seen this before? I've wrenched for 20 years.
Possible to convert it to normal tapered rollers and a real seal? Our do i just really need to find a p30 axle?
Riding in the Passing Lane
They are called conical brgs. They were used for many years back then on the wheel brgs & diff. carrier brgs. The replacements are normal tapered roller brgs.You are supposed to replace both inner & outer if you need to replace one. It seems to me it should have a seal in it. Ive been in a lot of them & never saw one without a seal.
1972 Chevy c10 Cheyenne Super
