| | | Forums66 Topics128,131 Posts1,056,369 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2001 Posts: 17 Member | | Member Joined: Aug 2001 Posts: 17 | I have a 3 and a 5 window. The three has no rust anywhere and the 5 has a rotted floorboard. Is it easy to remove the 5 window top and switch it with the 3 windows bottom of cab to make a new rust free 5 window cab? Should I just repair the entire floorboard on the rotted 5 window cab? Another catch is the 5 window cab needs to go on the 3 window's chassis. | | | | | Joined: Oct 2001 Posts: 194 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 194 | Shouldn't be any problem to switch cabs from one frame to another.
In the book " How to Restore Your Chevrolet Pickup" this topic is discussed. You can get it from Amazon.com
:p | | | | | Joined: Aug 2001 Posts: 17 Member | | Member Joined: Aug 2001 Posts: 17 | Sorry, I was not clear. What I am thinking about doing is cutting the top, below the rear window, from the 5 window and welding it to the 3 window bottom. I am wondering if that is easier than replacing a floorboard. Basically I want to swap roofs and rear windows. | | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | The hard jpart is the spot welds are hidden in the rear. They are tucked up inbetween the inner and outer panels. I plan on doing it on my cab, but I have removed the inner panel for the top chop and that will make it much easier. I will take a look today and see how it could be done.
1948 Chevy Pickup Chopped and sectioned owned since 1974 when I was 15.
| | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | If the 5 window only has a rotten floorboard then it should be preserved. It is in too good a shape to justify destroying one of those cabs.
I was shopping for a 5 window but found a 3 window I couldn't pass up. Now I like the 3 window better. I think it has more of a period look with the small rear window.
Fix them both.
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Aug 2001 Posts: 17 Member | | Member Joined: Aug 2001 Posts: 17 | I plan on fixing both up, so I probably should just fix the floorboard. Becasue of budget and a 3rd project ('68 Camaro w/454) I have no cash. Therefore, I am trying to get one of the AD's on the road quickly so the woman does not leave me I guess rather than swapping tops between two trucks, I could just do the floorboard repair. | | |
