2 members (Woodcmiami, Mike Roache), 138 guests, and 2 robots.
Topics128,101
Posts1,056,181
Members48,436
I have a 3 and a 5 window. The three has no rust anywhere and the 5 has a rotted floorboard. Is it easy to remove the 5 window top and switch it with the 3 windows bottom of cab to make a new rust free 5 window cab? Should I just repair the entire floorboard on the rotted 5 window cab? Another catch is the 5 window cab needs to go on the 3 window's chassis.
Shouldn't be any problem to switch cabs from one frame to another.
In the book " How to Restore Your Chevrolet Pickup" this topic is discussed. You can get it from Amazon.com
:p
Sorry, I was not clear. What I am thinking about doing is cutting the top, below the rear window, from the 5 window and welding it to the 3 window bottom. I am wondering if that is easier than replacing a floorboard. Basically I want to swap roofs and rear windows.
The hard jpart is the spot welds are hidden in the rear. They are tucked up inbetween the inner and outer panels. I plan on doing it on my cab, but I have removed the inner panel for the top chop and that will make it much easier. I will take a look today and see how it could be done.
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
If the 5 window only has a rotten floorboard then it should be preserved. It is in too good a shape to justify destroying one of those cabs.
I was shopping for a 5 window but found a 3 window I couldn't pass up. Now I like the 3 window better. I think it has more of a period look with the small rear window.
Fix them both.
54 3100 with 235
62 flatbed dump C60 with 261
I plan on fixing both up, so I probably should just fix the floorboard. Becasue of budget and a 3rd project ('68 Camaro w/454) I have no cash. Therefore, I am trying to get one of the AD's on the road quickly so the woman does not leave me wink
I guess rather than swapping tops between two trucks, I could just do the floorboard repair.
