Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (Bill Hanlon, Otto Skorzeny, Gdads51, Cosmo, MickeyP), 59 guests, and 0 robots.
Topics128,007
Posts1,055,279
Members48,418
Working on my 1950 3800 with the swapped-in 1959 235 motor with original carb (she used to have a 216). The spring that provides tension to the accelerator pedal appears to hook to the lip of the oil pan beneath it.
Is there a little tang/tab for properly attaching that spring to the oil pan?
Maybe something that uses one of the oil pan bolts to hold it in place? I don't recall seeing anything when I took the old motor out but after 60 years who knows what had been done to the old gal.
Thx - Bruce
The spring on the '48 2 ton 235 hooks on the same way.
Use this tab attached by a pan bolt as you surmised.
http://www.oldchevytrucks.com/cart/index.asp?sdes=MEE295
Drew
oh darn, now I'm going to have to get one.
