1 members (Bill Hanlon),
167
Mod | | | Forums66 Topics128,196 Posts1,057,386 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 430 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 430 | Both of my parking brake cables are broken. Has anyone had any luck finding replacements or will I be building my own? I have a 46 2-ton Chevy.
| | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I've had these guys build me cables. http://www.fleetpride.com/ | | | | | Joined: Nov 2010 Posts: 430 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 430 | Paul and Don, I will try both places tomorrow. Thanks for the info. | | | | | Joined: Jan 2010 Posts: 120 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 120 | Mine were rusted on my 47 1.5 ton. I got new ones made. Any cable shop can make new ones. What I learned: Aim for original spec inner. The shop made lighter ones, they operate under a lot of tension, mine are elastic, it doesnt help. Careful of the cast iron mount brackets on the backing plate and chassis, they are not strong and will split if you force them open too far. Which isnt very far at all. you will nedd to reuse the y- shaped threaded fittings for the pins at each end. Ths cable shop will have the threaded cable ends. Add rubber boots at each end to keep dirt out. and good luck.
'47 Canadian RHD 1.5 ton truck
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | anyoldiron, interesting to me you had them made at a cable shop. Never heard of a cable shop. Tried yellow pages and didn't find anything. What would you search for or how would you find one?
Dennis
40 Chevy 1/2 ton
