2 members (JW51, TUTS 59), 133 guests, and 4 robots.
Topics128,089
Posts1,056,362
Members48,442
Does anyone know if the 12 volt coils with the built in resistor do they work better than having an external resistor ?
Simple and reliable. But, No way to provide a hot spark on start. What is the cost? More or less than a new coil and resistor? They work fine and cost, or availability would be the only reason to use one.
Steve H
I'm using one and no issues. 12 volts with the old 6 volt starter so it spins pretty darn fast. Never had an issue.
Dennis
40 Chevy 1/2 ton
Riding in the Passing Lane
The internal resistance coils are made for low RPM & few cylinder engines, like tractors. If they worked on highway vehicles the manufactors would have used them.
1972 Chevy c10 Cheyenne Super
This is from the Jim Carter catalog for item EL158
"This item is a traditional round 12 volt coil but has a built in reducer. Eliminates the need for outside reducer EL181 when changing to a 12 volt system, includes mounting bracket....Can be used on 6 cylinder engines from 1937 - mid 1955 when the 6 volt system is changed to a 12 volt. (Remember the ignition points in even a 12 volt system will only operate on 6 volts, through the 1970's)...Sold each...Made in USA".
This is the coil I have been running on the 54' 235 in my 50' (12-volt converted) for the last four years. No external resistor, no burned points or other issues.
This forum really needs a "beating a dead horse" smiley!
http://s551.photobucket.com/user/bluecynder/media/Emoticons/Beating_A_Dead_Horse.gif.html
Pertronix makes a 12 volt internal resistor coil.Flame Thrower Pt# 40511 Black. This coil is suppose to be a much hotter spark.
Like the "Beating a dead horse" emoticon! thumbs_up
1970 VW Beetle
