4 members (TUTS 59, PAUL Berardi, wilbur53, 1 invisible), 112 guests, and 0 robots.
Topics128,132
Posts1,056,376
Members48,441
#1069050 11/19/2014 1:59 AM
I am wiring the ignition switch on my '54 chevy pickup and cannot get it right. There are only 3 posts, I get no power with the key all the way to the right and can only start it when the key is in the middle position (accessory). Is it a faulty switch or am I just being stupid?
Is that the stock switch? My 54' only has two positions... off and on. three posts on the back.
It is not stock, it is a new replacement, if yours has only two positions then that may be my problem
If it is a new switch, does it have letter labels next to the posts on the rear of it?
I do not see any markings
Gary, what makes you think the middle position is 'accessory'? there was no accessory position on 6V switches, just on/off, and any switches I've seen with an accessory position, it's furthest left [CCW] - maybe you'll have a switch that works: OFF-ON-OFF with the stock wiring
Gary, the switch in my '53 works exactly the same way (to the right=off, straight up=on). There is a discussion in another thread as to whether this is the way it is supposed to be:
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=1068423#Post1068423
1953 Chevrolet 3104 1/2-Ton
More pix
