| | | Forums66 Topics128,127 Posts1,056,357 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 26 New Guy | | New Guy Joined: Jul 2013 Posts: 26 | I am wiring the ignition switch on my '54 chevy pickup and cannot get it right. There are only 3 posts, I get no power with the key all the way to the right and can only start it when the key is in the middle position (accessory). Is it a faulty switch or am I just being stupid? | | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | Is that the stock switch? My 54' only has two positions... off and on. three posts on the back.
| | | | | Joined: Jul 2013 Posts: 26 New Guy | | New Guy Joined: Jul 2013 Posts: 26 | It is not stock, it is a new replacement, if yours has only two positions then that may be my problem | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If it is a new switch, does it have letter labels next to the posts on the rear of it?
| | | | | Joined: Jul 2013 Posts: 26 New Guy | | New Guy Joined: Jul 2013 Posts: 26 | I do not see any markings
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Gary, what makes you think the middle position is 'accessory'? there was no accessory position on 6V switches, just on/off, and any switches I've seen with an accessory position, it's furthest left [CCW] - maybe you'll have a switch that works: OFF-ON-OFF with the stock wiring
Bill | | | | | Joined: Oct 2013 Posts: 122 'Bolter | | 'Bolter Joined: Oct 2013 Posts: 122 | I am wiring the ignition switch on my '54 chevy pickup and cannot get it right. There are only 3 posts, I get no power with the key all the way to the right and can only start it when the key is in the middle position (accessory). Is it a faulty switch or am I just being stupid? Gary, the switch in my '53 works exactly the same way (to the right=off, straight up=on). There is a discussion in another thread as to whether this is the way it is supposed to be: https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=1068423#Post1068423 | | |
