6 members (Samantha, dt235sd, homer52, chevyb, wilbur53, 32Fordpuchoptop), 122 guests, and 4 robots.
Topics128,088
Posts1,056,124
Members48,435
#1069013 11/18/2014 8:27 PM
Well I didn't take good pictures of the headlamp assemblies when I took it apart and now I am trying to put it back together this truck has 4 headlights
1 when I install the headlamp bucket are the adjusting screws at the top and side or the bottom and side
2 where do I hook the springs
3 does anyone have any pictures they could E-Mail me or where can if find pictures of the headlight showing how they fit in ( [email protected] )
4 is there a difference in left and right side
5 with two headlights is the high beam on the inside or the out side
Thanks for any help you can give
Bob May
Sir Searchalot
Sir Searchalot
http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=109
All your answers are here. High beam inboard.
Thanks this will help
Bob May
Sir Searchalot
Sir Searchalot
Sealed beams may be marked "1" for inboard lamp and "2" for outboard. The LMC pic is looking at drivers side. Springs are located between the two lamp pair.
Riding in the Passing Lane
The left & right are the same but the inner & outer are different. The hi/low goes outside & the high only goes inside.
1972 Chevy c10 Cheyenne Super
Thank to everyone for your help
Bob May
