Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (baldeagle), 62 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#1068503 11/15/2014 10:30 AM
I have a 53 chevy truck I have a in line ballast resistor with ignition coil does anyone know if I need that extra wire coming off side post of starter switch that classic parts says to run in aid of starting ?
sal moreno #1068507 11/15/2014 10:47 AM
It can help with cold starts. And it was standard on the Task Force Trucks. If you have the starter switch with the post I would use it. Just a wire from the post to the coil. A couple of zip ties and off you go. Cheap and easy way to help with cold starts.
Steve H
sal moreno #1068510 11/15/2014 10:55 AM
Ok I will use it I wasn't sure if the truck would start without it ?
It will start and run with out the extra wire from the starter, just helps get a good hot spark with the starter pulling hard on the battery.
Steve H
