2 members (TUTS 59, Maybellene), 157 guests, and 2 robots.
Topics128,089
Posts1,055,988
Members48,430
#1063961 10/23/2014 2:43 AM
I have a 327 eng.today I bought a new set of fly wheel bolts to find I am in mess.the old set are metric.chhecking with different,5storesi find out everone only sells American standard.7/16 fine..whats the real answer guys? thanks
Sir Searchalot
Sir Searchalot
LS1 (gen III) has metric bolts, flywheel is M11 x 1.5 (11 MM). That would be about a 347-348 Cu In motor. This would be called by many as a good old 350/5.7. McMaster Carr and others have metric bolts. Ace hardware has metric bolts. Dealer has them. ARP has them. Jeggs, Summit, RockAuto. Be sure you know what size/pitch/length you have. Most other SBC have 7/16-20 as you say. Quickest place: O'Reilly's has M11 X 1.5 under 1998 Corvette. Part No. 330-2802.
I don't know what motor you have or what bolts, so the above is just food for thought. If you ask for 327 bolts you will get 7/16-20.
johnhull #1068399 11/14/2014 10:06 PM
agree not metric fine threads . Also a thiner bolt head , at least that was the case with my 327 365 horse solid lifters. ( 1965 ) Good luck
WP38 #1068450 11/15/2014 2:03 AM
7/16-20 are a common grade 8 bolt size, but as said the heads are too thick. You could machine the heads down.
