| | | Forums66 Topics128,077 Posts1,056,014 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 149 | I have a 327 eng.today I bought a new set of fly wheel bolts to find I am in mess.the old set are metric.chhecking with different,5storesi find out everone only sells American standard.7/16 fine..whats the real answer guys? thanks | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | LS1 (gen III) has metric bolts, flywheel is M11 x 1.5 (11 MM). That would be about a 347-348 Cu In motor. This would be called by many as a good old 350/5.7. McMaster Carr and others have metric bolts. Ace hardware has metric bolts. Dealer has them. ARP has them. Jeggs, Summit, RockAuto. Be sure you know what size/pitch/length you have. Most other SBC have 7/16-20 as you say. Quickest place: O'Reilly's has M11 X 1.5 under 1998 Corvette. Part No. 330-2802. I don't know what motor you have or what bolts, so the above is just food for thought. If you ask for 327 bolts you will get 7/16-20.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Nov 2014 Posts: 13 New Guy | | New Guy Joined: Nov 2014 Posts: 13 | agree not metric fine threads . Also a thiner bolt head , at least that was the case with my 327 365 horse solid lifters. ( 1965 ) Good luck | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | 7/16-20 are a common grade 8 bolt size, but as said the heads are too thick. You could machine the heads down. | | |
