4 members (Southerntruck, Phak1, DaveV, 2-Ton), 90 guests, and 2 robots.
Topics128,035
Posts1,055,566
#1068075 11/13/2014 4:05 AM
7
7 Offline
Does anyone have any info or pics of the original truck jack for a 3100 1950 Chevrolet ?
1950 Chevrolet 1300 - Canadian Built
This truck is now for sale (9/2016)
All Original
More pix in Bolt Bucket
7998 #1068078 11/13/2014 4:12 AM
7998 #1068094 11/13/2014 5:39 AM
Thanks Tim
That is exactly what I was looking for as well!
1951 Chevy 3100 5-Window
"Howard"
More pix on Photobucket
7998 #1068313 11/14/2014 12:36 PM
7
7 Offline
Thanks for the info.
How about spare tire lock ?
All Original
7998 #1068319 11/14/2014 1:19 PM
7998 #1068330 11/14/2014 3:16 PM
I would be interested in the same kind of information for a 55-59 3100 TF truck.
TIA.
Brian
Brian
1955.2 3100 Truck
7998 #1068341 11/14/2014 4:41 PM
7998 #1068449 11/15/2014 1:57 AM
Thank you Tim. Would it be fare to say it would be about the same shape as the 1950 one?
Brian
Brian
1955.2 3100 Truck
7998 #1068452 11/15/2014 2:10 AM
Brian,
A Task Force person would know. Someone will post information.
7998 #1068482 11/15/2014 5:17 AM
yes, the TF jack is a similar screw jack except the top of the screw is a disc shape 'checkered' piece like a modern bottle jack instead of the U shape piece - shown in the Assembly Manual sect 14, sheet 15/16 .... the same up to about '72 I believe
7998 #1068484 11/15/2014 5:30 AM
Thank you Bill.
Brian
Brian
1955.2 3100 Truck
7998 #1068980 11/18/2014 4:18 PM
Another question, does anybody have information to where the jack would be positioned when changing a tire front and rear on a TF 3100 series truck?
TIA.
Brian
Brian
1955.2 3100 Truck
7998 #1069334 11/20/2014 5:30 PM
Did I stump the panel?
Brian
Brian
1955.2 3100 Truck
7998 #1069340 11/20/2014 5:55 PM
there isn't a 'factory' answer, but don't try it with beer in hand grin the most effective and safest place should be your choice, which depends on the exact situation - are you on the gravel verge of a country road? your compound sloped driveway? your modern garage? usually under a spring pad to avoid needing to jack too high
7998 #1069508 11/21/2014 4:02 PM
Bill, understand, just thought the factory had a specific place to position the jack like vehicles have now a days. Again thank you for the reply.
Brian
Brian
1955.2 3100 Truck
