| | | Forums66 Topics128,091 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 8 New Guy | | New Guy Joined: Jul 2014 Posts: 8 | So I just purchased a 1951 GMC truck with a chevy 235 engine and a new 6v battery sitting in it but not hooked up. The previous owner passed away years ago. The truck has a 12v alternator, large white resistor on the firewall and the coil "-" to the distributor. I'm thinking I need a 12v battery with a negative ground hook-up. Just need some reassurance, I don't want to fry my gauges. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What you describe is a safe bet.
Is there a resistor on the input lead on the fuel gauge?
Most likely, all light bulbs are already 12v.
If you have a heater and the motor is 6V, you might want a resistor on the input lead. Maybe someone will comment on the placement of this resistor (before the speed-control switch or after the switch).
| | | | | Joined: Jul 2014 Posts: 8 New Guy | | New Guy Joined: Jul 2014 Posts: 8 | Thank you! The fuel gauge pegged full so i'll need to get a resistor but nothing smoked. | | | | | Joined: Mar 2010 Posts: 10,278 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,278 | Does the gauge peg with the ign switch on? That usually is a symptom of no ground from the top of the sending unit. 12 volts to a 6 volt gauge should not damage the gauge or sending unit, it just won't read correctly. Carl
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Does the gauge peg with the ign switch on? [1] That usually is a symptom of no ground from the top of the sending unit. [2] 12 volts to a 6 volt gauge should not damage the gauge or sending unit, it just won't read correctly. Carl [1] Yes [2] No damage to the sending unit (simply described as a variable resistor); but, the 6v gauge might be wounded/fried. A 12v to 6v runtz-style reducer on the input side of a 6v fuel gauge is recommended by most people. | | |
