4 members (59 fleet, 3800GUY, Charles in CA, IHPWR), 144 guests, and 4 robots.
Topics128,107
Posts1,056,225
Members48,436
#1067738 11/11/2014 6:08 PM
So I just purchased a 1951 GMC truck with a chevy 235 engine and a new 6v battery sitting in it but not hooked up. The previous owner passed away years ago. The truck has a 12v alternator, large white resistor on the firewall and the coil "-" to the distributor. I'm thinking I need a 12v battery with a negative ground hook-up. Just need some reassurance, I don't want to fry my gauges.
What you describe is a safe bet.
Is there a resistor on the input lead on the fuel gauge?
Most likely, all light bulbs are already 12v.
If you have a heater and the motor is 6V, you might want a resistor on the input lead. Maybe someone will comment on the placement of this resistor (before the speed-control switch or after the switch).
Thank you! The fuel gauge pegged full so i'll need to get a resistor but nothing smoked.
Does the gauge peg with the ign switch on? That usually is a symptom of no ground from the top of the sending unit. 12 volts to a 6 volt gauge should not damage the gauge or sending unit, it just won't read correctly.
Carl
[1] That usually is a symptom of no ground from the top of the sending unit.
[2] 12 volts to a 6 volt gauge should not damage the gauge or sending unit, it just won't read correctly.
Carl
[1] Yes
[2] No damage to the sending unit (simply described as a variable resistor); but, the 6v gauge might be wounded/fried.
A 12v to 6v runtz-style reducer on the input side of a 6v fuel gauge is recommended by most people.
