8 members (cmayna, baldeagle, Bill Hanlon, Leo, Hotrod Lincoln, Mike in Sycamore, Gdads51, 1955 1 Series),
120
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,113 Posts1,056,280 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | On my '50 COE, the air cleaner is mounted next to the battery box, under the passenger seat. There is a long tube that sweeps forward and to the driver's side that attaches to the carb. This is not the best place in terms of drawing in relatively clean air. http://s1116.photobucket.com/user/1950Cabover/media/IMG_0906_zps9728252e.jpg.html?sort=3&o=7This link show a photo of the air cleaner from behind. The air cleaner is against the inside of the right frame rail and is tucked in just to the right of the transmission. Kent | | | | | Joined: Sep 2014 Posts: 19 New Guy | | New Guy Joined: Sep 2014 Posts: 19 | I wonder what year they moved it to under the hood? I will just cut off the air cleaner mounting parts and bolt them to the refurbished radiator support. Real nice truck by the way.
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Are we talkng about a GMC COE, & a Chevrolet COE ? If so, that was one of the evident differences in the two makes. If not someone in the past, made the improvement. All '47-'55 1st series GMC COE's have there air cleaner under the hood with the throat of the updraft carb. facing forward. On a '47-'53 Chevrolet COE the air cleaner is under the cab floor as Lightholder's Dad mentioned, with the carb. throat facing the rear. 1954, & '55 Chevrolets were the same as the GMC's. I've changed the carburetors, & air cleaners on two (a '51, & a '53)Chevy COE's, to get them from under the floor. | | | | | Joined: Dec 2011 Posts: 99 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 99 | Great idea Spanky, as usual. My 53 Chev is down on the passenger frame rail as you stated,a foot or two rear of the draft tube. Can't be the best spot for it
Geo | | |
